SXT LTE6 link down and up each 4 hours
Hello, I’m new on this forum, I hope I selected the correct category.
I’ve a MikroTik SXT LTE6 modem with RouterOS 6.47, I suffer from LTE link down and up each 4 exactly hour, as you can see in the log attached below.
I’ve alredy update LTE firmware to revision R11e-LTE6_V025, but the problem is still present.
LOGS
aug/04 21:10:56 interface,info lte1 link down
aug/04 21:11:03 interface,info lte1 link up
01:10:57 interface,info lte1 link down
01:11:04 interface,info lte1 link up
05:10:57 interface,info lte1 link down
05:11:04 interface,info lte1 link up
08:39:40 dhcp,info defconf assigned 192.168.88.248 to A4:50:46:3D:E1:2B
08:44:43 dhcp,info defconf assigned 192.168.88.253 to 74:E5:F9:15:F4:D2
08:50:13 dhcp,info defconf deassigned 192.168.88.247 from 7C:2E:DD:5C:8F:EC
08:51:19 dhcp,info defconf deassigned 192.168.88.249 from 7C:2E:DD:4F:D7:EE
09:10:58 interface,info lte1 link down
09:11:05 interface,info lte1 link up
09:11:26 system,info,account user admin logged in from 192.168.88.253 via web
09:27:25 system,info,account user admin logged out from 192.168.88.253 via web
11:48:13 dhcp,info defconf assigned 192.168.88.249 to 7C:2E:DD:4F:D7:EE
11:57:26 dhcp,info defconf assigned 192.168.88.247 to 7C:2E:DD:5C:8F:EC
13:10:58 interface,info lte1 link down
13:11:05 interface,info lte1 link up
14:27:16 dhcp,info defconf deassigned 192.168.88.247 from 7C:2E:DD:5C:8F:EC
14:44:04 system,info,account user admin logged in from 192.168.88.253 via web
14:48:24 system,info,account user admin logged in via local
15:14:43 system,info,account user admin logged in via local
LTE Interface info
[admin@MikroTik] > /interface lte info lte1 once
pin-status: ok
registration-status: registered
functionality: full
manufacturer: “MikroTik”
model: “R11e-LTE6”
revision: R11e-LTE6_V025
access-technology: Evolved 3G (LTE)
session-uptime: 1h48m20s
primary-band: B20@10Mhz earfcn: 6200 phy-cellid: 60
rssi: -47dBm
rsrp: -76dBm
rsrq: -10.5dB
sinr: 22dB
cqi: 15
ri: 2
Any idea how to solve this problem? Could if depend from the mobile operator?
Thanks,
Riccardo
Try with different operator. Is possible that your operator each 4 hours kick all clients on his BTS’s.
Your signal levels are really good.
Regards.
I opened a ticket to the operator, and they checked the antennas and they replied me they didn’t find any problem. I can’t change operator, because this is the only available operator close to my home.
Any check I can do on my modem?
Thanks,
Riccardo
Such a feedback only means that everything is working as designed on their side, which may still include the 4 hour lifetime of a single connection. Plus the frontline helpdesk may not even understand what your actual issue is, so they just look at their network monitoring system whether nothing is shown in red in your geographical area and if it is not, they report back that “everything is working”.
A regular disconnect every 4 hours is not likely to be caused by a modem fault. Do you have a contract with a fixed IP for that SIM? If not, you should be getting a different IP address for each connection. If so, can you test the same SIM in your smartphone, switch off the WiFi, leave it at the same place with good signal overnight, and check the IP address in the evening and in the morning (so that at least one full 4-hour interval passes between the checks) without moving the phone?
If the signal is so weak that you need the SXT to even catch it, you’ll have to use a satellite dish for the test, place the phone instead of the LNB to the focus of the mirror, and align the antenna for the strongest signal (the position may look strange as the satellite antennas are typically offset ones, so the axis of the parabol is not orthogonal to the front).
Good point checking the IP on the phone then of 4 hours.
On the other hand, I think that disconnection is a problem because it can interrupt connections unexpectedly. You can Download a big file (For example this), but before, limit your speed connection to some Kbps using a simple queue and see what happens after 4 - 4 and half hour. If is an active connection, not always your IP is renewed.
Regards.
