Hoping you can help with an issue I’m facing with an SXT with LTE6 modem.
In testing, the unit was fine, but it became unhappy after a power cycle. The LTE interface disappeared entirely and it transpires that it had lost its LTE package, so I reinstalled it.
The unit now has its LTE interface back, but I’m unable to get a connection using previously valid APN settings.
LTE logging yields the following entries: lte1: sent ATE0 followed by lte1: reply timeout for: ATE0
The modem is also unable to scan for networks and gives an error (6 - modem not yet configured)
I’ve tried several factory resets unsuccessfully.
I’ve tried the SIM in another device and it’s fine, I’ve also tried the other SIMs in the SXT and it still doesn’t work.
I sense I’m missing a bit of basic configuration for the modem which was lost when it lost its package.
Did you reset configuration on Quick set up page ?
I am learning to use this device too ! i have tried various mikrotik products.
not sure i can help with deep knowledge but happy to assist any way i can
Yeah, tried that, eventually ended up Netinstalling it to totally wipe it and still wasn’t right.
I’ve RMA’d it today and await a replacement, spent three days solid trying to get it to work and eventually put it down to hardware failure. Disappointing
