I’m really struggling with wireguard on my SXT LTE. I really wish MT would allow the Back to home on this, like my old hAPac2, but hey ho.
I’m starting with a default config so I can try to understand this.
It all looks ok, the wireguard on the W11 shows connected, but I’m unable to winbox into the SXT.
here is my MT config
[admin@MikroTik] > export hide-sensitive
# 2024-07-16 19:07:16 by RouterOS 7.15.2
# software id = 17MM-EWUD
# model = SXTR
# serial number = xxxxxxx
add admin-mac=xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
/interface lte
set [ find default-name=lte1 ] allow-roaming=no band="" sms-read=no
/interface wireguard
add listen-port=51820 mtu=1420 name=wg0
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] apn=vodafone.co.uk ip-type=ipv4 use-network-apn=no
add name=default-dhcp ranges=192.168.188.10-192.168.188.254
add address-pool=default-dhcp interface=bridge name=defconf
/queue type
add fq-codel-ecn=no kind=fq-codel name=fq-codel-ethernet-default
/queue interface
set ether1 queue=fq-codel-ethernet-default
set ether2 queue=fq-codel-ethernet-default
add comment=defconf interface=lte1 list=WAN
/interface wireguard peers
add allowed-address=10.0.0.2/24 endpoint-address=XXXXXXXX.sn.mynetname.net \
endpoint-port=51820 interface=wg0 name=peer1 public-key=\
"iip8dCtE--------------------------4fluirwk="
add address=192.168.188.1/24 comment=defconf interface=bridge network=\
192.168.188.0
add address=10.0.0.1/24 interface=wg0 network=10.0.0.0
/ip cloud
set ddns-enabled=yes
add address=192.168.188.0/24 comment=defconf dns-server=192.168.188.1 gateway=\
192.168.188.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.188.1 comment=defconf name=router.lan
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=accept chain=input dst-port=51820 protocol=udp
add action=accept chain=forward dst-address=192.168.188.0/24 src-address=\
10.0.0.0/24
add action=accept chain=forward dst-address=10.0.0.0/24 src-address=\
192.168.188.0/24
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
add action=masquerade chain=srcnat out-interface=lte1
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
"defconf: drop everything else not coming from LAN" in-interface-list=!LAN
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/system clock
set time-zone-name=Europe/London
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
[admin@MikroTik] > /ip
here are the screenshots of my W11 Wireguard setup.
https://forum.mikrotik.com/download/file.php?mode=view&id=67637
https://forum.mikrotik.com/download/file.php?mode=view&id=67638
https://forum.mikrotik.com/download/file.php?mode=view&id=67636
Would someone please give me a hand?
All i want to do (at the moment) is remote login to winbox on the device.
Thank you.
