ive got ab problem between an Omnitik (AP bridge) an SXT (Station Bridge)
I used NV2.
After a few hours client was not connected, Error in Log:
10:11:57 wireless 00:0C:42:C3:40:0B@wlan1: lost connection, synchronization timeout
After this client dont want connecting again.
Only reboot helps.
Client did not found anything with search tab, after reboot all ok again.
any help?
mistry7
be sure of /
1- signal and ccq
2- direction ane elevation
3- wireless settings ( bad settings)
4- adapter connections
5- adaptor it self
good luckā¦
No kidding please
Distance 100m
Rx side -55
TX side -53
SNR 65db
Ccq 100%
Only One Client disconnects with the Message:
Omnitik in AP Bridge Mode
Only One Client in Station Bridge Mode (with issue)
6 Client in Station Mode (without issue)
All ROS 6.2
sonny
4
downgrade to 6.1 and check Routerboard firmware
lower tx power that you get -64 - -66 RX
Hi sonny,
do you think TX/RX Power is to high for the radio?
Current TX Power in SXT is 3db
Current TX Power in Omnitik is 12 dbm
SXT problem.tiff (55.5 KB)
