SXT perfekt ptp config??
Hi guys :smiley:
i’m trying to find the perfekt ptp config for my SXT’s!!
but so far i did’n find anything :confused:
maybe anyone can send me something useful (config. etc.)?
and another question: whats about nv2?
thx a lot!!
tom
See http://wiki.mikrotik.com/wiki/Transparently_Bridge_two_Networks
It’s a wireless bridge.
not a good link for SXT, because it doesn’t tell you to enable second wireless chain and configure NV2
So, what do you snuggest? How to do that (wireless chain)?
Here is a tutorial how to connect two SXTs:
http://www.wispforum.net/entry.php?6-How-to-Connect-two-Mikrotik-SXT-5D-s-In-Bridge-Mode-Part-II&goto=prev
Did you try this configuration? if yes, what was the real throughput and how much distance?
I am using this configuration now. The link shows 245 meg both directions, actual through put sxt to sxt is around 145 meg one direction, and about 95 meg through the link to a router. Subject to the limitation of a 100 meg Ethernet port on SXT’s.
Distance is about 1 mile.
Nice Job :smiley:
On the related subject I would like to ask something. I am trying to test two SXT antennas that are 3 meters apart. My question is how do I simulate a distance of 11 km instead of the 3 m. I did everything, connecting, setting up a bridge, ets.
Appreciate you help. Thanks
