i have sxt router
when i power it work normal and beep that it is ok
but when i try to open it with winbox it does not show
in winbox >??
what sould i do to solve this problem ???
i have sxt router
in winbox >??
Use link to get access to SXT,
http://wiki.mikrotik.com/wiki/First_time_startup
Connect Ethernet cable from your laptop to SXT directly.
Disable any other network interface (wireless for example).
Run Winbox on the laptop, click on ‘’…" to discover MikroTik routers in your network.
SXT will be shown there.
dear i do what u say but it didn’t show when i press " … "
and i insert the ip’s in the lan
192.168.88.22
255.255.255.0
192.168.88.1
it didn’t show ???
what shoul i do
Try to reset SXT board, reset is the option you need,
Use Reset button - S1400 This button has three functions. Hold the button, then apply power. Depending on when you
release the button, it will do these things:
• release immediately (0-5 seconds) after starting the device to load backup bootloader
• release when user LED starts to flash to reset RouterOS (5-10 seconds)
• release after user LED stops flashing to start Etherboot (Netinstall) mode
(10+ seconds)
Then try to access RouterBOARD one more time.
