Hi there,
I have a Mikrotik SXT Lte kit and I am a newbie, I have the following questions:
- when I connect to the Mikrotik via Winbox I see that it always starts with 0.0.0.0, even after resetting it. Do the default IP should not be 192.168.88.1 or 192.168.8.1?
- What exactly is the purpose of the 2th Ethernet port Poe Out?
- Where is it possible to configure DDNS (dyndns, noip…)?
- is it possible to use or install a Torrent client to download files when the computer is off?
- I have some credentials for OpenVPN: is it possible to use them on the Mikrotik to activate/deactivate the VPN of my provider?
