lo there… got a few sxt lite r3 that came with 6.34.4… 3.30 firmware and only 16mb of free space… can’t send image to device to upgrade…when i try it says not enough room..
solution?
It’s supposed to be progress. With smaller flash to brighter future!
You should be able to upgrade from RouterOS (System->Packages->Check For Upgrades), because that uses RAM as temporary storage. Other option is to use Netinstall.
