SXT-Sa to SXT P2MP multicast setup
Multicast streams are going from the IGMP enabled switch. I want to send the streams from SXT-Sa to couple of SXT-s. What will be the correct settings for both ap and the client side so, the stream is not broadcasted to all the stations but only those who are joining the stream ?
Ubnt is simple, just turn multicast helper on on the ap and thats it, but turning multicast helper on on the SXT-Sa does not have any effect, the stream is broadcasted to all the clients.
Kind Regards.
Aleksander
Post your configs
