SXT SA5 AC link bandwidth issue
I am using two SXT SA5 AC for 5 km link we need 100 MBPS bandwidth for wisp backhaul link. we are getting 25 to 30 mbps bandwidth. is there special config setting for AC product.
Access point config
add name=bridge1 protocol-mode=none
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=
20/40/80mhz-eeeC country=austria disabled=no frequency=5240 l2mtu=1600
mode=ap-bridge name=wlan1-gateway nv2-preshared-key=pcpl@h2r
nv2-security=enabled radio-name=“HOME TO RANKALA” rate-set=configured
wds-default-bridge=bridge1 wds-ignore-ssid=yes wds-mode=dynamic
wireless-protocol=nv2
set [ find default-name=ether1 ] name=ether1-local
/ip neighbor discovery
set wlan1-gateway discover=no
add address-pool=default-dhcp disabled=no interface=ether1-local name=default
/interface bridge filter
add action=set-priority chain=forward new-priority=7
add bridge=bridge1 interface=ether1-local
add bridge=bridge1 interface=wlan1-gateway
add address=192.168.245.215/24 comment=“default configuration” interface=
ether1-local network=192.168.245.0
/ip dhcp-client
add comment=“default configuration” dhcp-options=hostname,clientid disabled=
no interface=wlan1-gateway
add address=192.168.88.0/24 comment=“default configuration” dns-server=
192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment=“default configuration” connection-state=
established,related
in/out-interface matcher not possible when interface (wlan1-gateway) is slave - use master instead (bridge1)
add action=drop chain=input comment=“default configuration” in-interface=
wlan1-gateway
add chain=forward comment=“default configuration” connection-state=
established,related
add action=drop chain=forward comment=“default configuration”
connection-state=invalid
connection-nat-state=!dstnat connection-state=new in-interface=
wlan1-gateway
add action=masquerade chain=srcnat comment=“default configuration” disabled=
yes out-interface=wlan1-gateway
/queue interface
set wlan1-gateway queue=only-hardware-queue
/system identity
set name=“HOME 2 RANKALA”
/system leds
set 0 interface=wlan1-gateway
/system routerboard settings
set cpu-frequency=720MHz
/tool mac-server
add interface=ether1-local
/tool mac-server mac-winbox
Station Bridge config
add name=bridge1
/interface wireless
mode=station-bridge nv2-preshared-key=pcpl@h2r nv2-security=enabled
radio-name=“RANKALA TO HOME” ssid=“HOME 2 RANKALA” wds-default-bridge=
bridge1 wds-mode=dynamic wireless-protocol=nv2
add address=192.168.245.216/24 interface=ether1 network=192.168.245.0
/ip dhcp-client
add dhcp-options=hostname,clientid interface=bridge1
/ip firewall mangle
add action=set-priority chain=output new-priority=7 protocol=icmp
/queue interface
set wlan1 queue=only-hardware-queue
/system identity
set name=RANKALA_HOME
You haven’t post wireless link status but anyway you had choose the wrong product for 5km and also for a backhaul link. Your signal is most likely very weak. That antenna is for sector coverage.
