SXT testing results
One of our customers sent us this test result. We have similar results, and are happy to see that customers get the same:
Is there any tools can show the actual TCP traffic as the UDP always not so accurate…
Like when this case tested is 100++ Mbps, but if real traffic flow, i dun think it can go for that speed…
it depends on what you mean by “real traffic”. it’s different for everyone. that’s why we use UDP test so that results are consistent and can be compared.
Please post test in TCP and settings of the wireless
It’s not our test, it’s from a chinese forum.
I understand. But I would like official test from Mikrotik
UDP is always the better looking test for MT to use as it always shows results far higher that what you can actually get in reality
not true! it’s only reasonable to test the absolute maximum possible. there needs to be some measuring point where all the tests can be compared, you can’t run speedtest.net and expect it to be even remotely accurate, or even to try and compare that result to other routers. Not all web traffic is small TCP packets. There are all kinds of requirements and not everyone needs the SXT for online gaming for example.
UDP is always higher and higher is better for MT :stuck_out_tongue:
How can you say UDP is the only one where all the tests can be compared? TCP isn’t much different but does strain the routerboard a little more.
In our experience TCP test’s are more in-line with what we can push than UDP test, We never see close to UDP speed results in a real ISP enviroment
same here
Good result. How far it was ? Signal levels ? Configuration ? 2chain or 1chain , 20 or 40Mhz width ?
Its would be first time for me to see 2chain stable link. May be we are doing something wrong, but using 1 chain we got always very nice stable links on 20MHz od 40Mbjt channel, but something is always wrong after going to 2chain setup. Its speed is everytimes very unstable.
Our units arived today, so looking forward to see results
Be nice if f SXTs came with a baseline configuration for PtP so we only had to change SSID and Channel. Right now there is so much trial and error involved :frowning:
Obviously all environments are different but there must be a common starting point?
SXT supports Flashfig out of the box, so you can do one-click configuration out of the box.
http://wiki.mikrotik.com/wiki/Flashfig
Flashfig - new to me - cool
Waiting for my SXT’s now - looks very interesting
Rod
nice, but we are still missing default recommended values.
You should be politician :slight_smile:
Here is my test result:
Site A
  1. Notebook HP Probook Corei3
  2. 4GB Memory
  3. Broadcom Ethernet
  4. Mikrotik RB/SXT
  5. Firmware version 4.16
Site B
  1. PC Dual Core
  2. Memory 2GB
  3. Realtek Ethernet
  4. Mikrotik RB/SXT
Software used : JPerf version 2
Protocol : TCP
Distance : Indoor, 5 meters, different room
You wanna print the wireless config?
great.
can you post your configuration here.
thanks
Would love to know a config where we can cheive anything like these speeds, the most i can get through these units at the moment is 30mbps tcp one way or symmetric seems fine,
please someone post a usable config for these units
manners, push though them not between them using TCP, as they are not to powerful to generate so many TCP traffic. Try UDP.
Also test out Nv2 protocol.
