The RB-SXT would be an excellent product to be used in multipoint because
1 - There’s nothing to assemble (it is ready to use)
2 - It has built-in LED signal for easy alignment
3 - It have MiMO 2x2 and this maximizes spectral efficiency
4 - Very practical
The problem is the LOW GAIN!!
Now, I ask because it will not released a more suitable product to the real world, ie
1 - A version with integrated 20dB (I think is the minimum to connect customers with the maximum modulation up to 7-8km)
2 - A version of the same except with 2 external connectors for a high-gain antenna (for customers of up to 20km)
The actual version has a gain of 16dB too low to be used in large scale on PTMP
Is there any prevision to release a SXT-20dB and SXT-ExtConnectorized?
It would be the perfect product that reflects the needs of us (Wisp)
I would start to improve our distribution network by installing and connecting customers to BTS 2x2 MIMO up to 20Km with decent signals (-75dB)
How many of you are interested?
And Normis, what do you think?
I tried a
RB711 + Grid 90cm x 60cm
vs
SXT + Offset 60cm
On the same AP cell with the Offset+SXT I got 3dB less than the other.
I thought that would make something better of the grid.
Probably would be better with a 5Ghz real feeder? SXT is too large to capture the perfect focus?
Have you tried the same offset dish with a real 5Ghz feeder?
The problem remains, however, on the sxt 16dB (up to 7-8km… call it standard antenna).
As I understand, many people say it would take at least one 20dB
Yes. But we need cost efficient not low cost. If I’m in need of a 20db CPE I’ve to
pay the price. It does not help there is a low cost 16db if I need 20db.
Low gain? Say what? My friend built new base station recently with Dual-Pol 17 dBi Sectoral antenna (HV). Radio was standard power (100 mW) and he did a quick test with SXT 5 km away from base station. The signals were STABLE -68/-69. SNR was great, CCQ near 100% and the best part - throughput. SXT could upload 20 Mbps and download 70-80 Mbps. Traffic was generated from laptop using Bandwith test. All stable. Period.
ok, and now… SXT has a 26 db tx power only when the data rate 6Mbit/s, yes? When MCS15 has only 19 db, yes? Now, put both sides into the calculator. about -72dB in the ideal state. The added noise, a reserve… SXT has a small gain. Intercede for the offset reflector as the canopy.
calculators already include some loss, and they add cable loss which is not there for the SXT. stop looking at the calculators and buy one SXT for testing. this is nothing spectacular, normal SXT performance
