Hi Forum,
I have 2 SXT’s, 5nd r2’s. Obviously one is station the other ap bridge.
I have set up a bridge interface and added both the wlan and ether1 interfaces to it, to create a bridged link on either end. Essentially trying to emulate a big ethernet link.
2 devices that use Multicast on either end cant seem to talk to each other.
If I do a similar setup but on a single 951-2n, both ports going through CPU and member of a bridge interface (so not using switch chip) the multicast works, but through the SXT’s it doesn’t appear to be. I can see the traffic hitting in and trying to send out (about 4-5mbit) but not getting anything back.
Is there a trick to getting multicast working between the Ether->wlan bridging on an SXT? Would I need to use some form of IGMP Proxy or other multicast routing?
The multicast package is installed on both, both running 6.17 currently.
Thanks,
Joe
