hi everybody
i have two sxt 5phnd and configured as point to point link but distance between two sxt is about 80 or 90 m
should i decrease TX power ?
and please advice me anythings that i should do
thanks very much
Yes it very short range decrease tx power to have signal between -50 and -60 in registration table.
Thanks alot
I change tx power from default to card rate = 8
Is this true ?
And another question is about link configuration
I setup one sxt as bridge and another one as station bridge
But in some document says set on side as bridge and another
Side station wds
Could you plz whats difrence between them
Really thank you
It is the some functionality make layer 2 bridge.
Main difference is station bridge working only between Mikrotik devices more information http://wiki.mikrotik.com/wiki/Manual:Wireless_Station_Modes
On my network I switch all p2p link to bridge, station bridge because not create additional wds interface and don’t need to enable wds in setting it is easier to set.
thank u for your time
could you please answer to this question too plz
Is this true ?if not please let me know
Check in wireless registration table signal strength change power to have signal between -50 to -60.
I thing on new devices like yours must use all rates fixed for settings tx power not default card rate but effect of this setting is visible on registration table.
thanks my friend
i get signal around -60 when i change tx power to 6 db
is this ok for radio ???
Yes it is ok.
thanks a lot …
