I’m planning to build some SXT units with the EM12-G for use in the US on Verizon, band 13. I’ve looked at the specs for the SXT and other posts that say it is possible and will work with ROS 7, but I haven’t been able to confirm if I’ll need jumpers from the modem to the board. Are these included with the SXT or do I need U.fl-MHF4 jumpers?
Are there any other issues anyone has encountered with this combination? Should it work fairly painlessly out of the box(es)?
Thanks all!
