SXT5 NV2 "lost connection, synchronization timeout"
Hello Everyone,
I’m Using two SXT5-Lite to connect my network with my neighbour. Distance: 30m; Direct Line of sight.
It worked for about 3 years, but in the last few month, we have a lot of disconnects and the connection drops for about 30-40 minutes. The same configuration works on another site since 2016 without any problems.
Today I added a watchdog on the neigbours side to minimize the downtime - but I’d be happy to find the root cause instead of constantly rebooting.
The errors are always the same:
(on the neighbours side SW16-SXT5-Dach):
apr/09 07:53:05 wireless,info 64:D1:54:1B:5E:EF@wlan1: lost connection, synchronization timeout
apr/09 07:55:43 wireless,info 64:D1:54:1B:5E:EF@wlan1 established connection on 5560000, SSID __SPW15/16-WAN-Conn__
apr/09 20:14:44 wireless,info 64:D1:54:1B:5E:EF@wlan1: lost connection, synchronization timeout
apr/09 20:15:47 wireless,info 64:D1:54:1B:5E:EF@wlan1 established connection on 5500000, SSID __SPW15/16-WAN-Conn__
apr/09 21:55:08 wireless,info 64:D1:54:1B:5E:EF@wlan1: lost connection, synchronization timeout
apr/09 21:56:13 wireless,info 64:D1:54:1B:5E:EF@wlan1: failed to connect, on 5660000, synchronization timeout
apr/09 21:58:11 wireless,info 64:D1:54:1B:5E:EF@wlan1 established connection on 5560000, SSID __SPW15/16-WAN-Conn__
apr/09 22:04:48 wireless,info 64:D1:54:1B:5E:EF@wlan1: lost connection, synchronization timeout
apr/09 22:26:04 wireless,info 64:D1:54:1B:5E:EF@wlan1 established connection on 5500000, SSID __SPW15/16-WAN-Conn__
apr/09 22:50:13 wireless,info 64:D1:54:1B:5E:EF@wlan1: lost connection, synchronization timeout
apr/09 23:02:05 wireless,info 64:D1:54:1B:5E:EF@wlan1 established connection on 5620000, SSID __SPW15/16-WAN-Conn__
apr/09 23:07:30 wireless,info 64:D1:54:1B:5E:EF@wlan1: lost connection, synchronization timeout
and so on…
Configurations:
Device “SW15”
# apr/11/2021 21:19:20 by RouterOS 6.48.1
# model = SXT 5nD r2
# name=BgSW15-SXT5-SAT
add fast-forward=no name=bridge1
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n channel-width=20/40mhz-Ce \
    country=austria disabled=no mode=bridge name=wlan2 nv2-preshared-key=\
    "*****" nv2-security=enabled ssid=__SPW15/16-WAN-Conn__ \
    station-roaming=enabled wireless-protocol=nv2 wps-mode=disabled
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
    dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=\
    ****** wpa2-pre-shared-key="******"
/interface wireless access-list
add interface=wlan2 mac-address=64:D1:54:BA:AC:4B signal-range=0 vlan-mode=\
    no-tag
[admin@BgSW15-SXT5-SAT] > /interface wireless monitor wlan2
                 status: running-ap
                channel: 5500/20-Ce/an/DP(11dBm)
      wireless-protocol: nv2
            noise-floor: -111dBm
     registered-clients: 1
  authenticated-clients: 1
      current-tx-powers: 6Mbps:8(8/11),9Mbps:8(8/11),12Mbps:8(8/11),
                         18Mbps:8(8/11),24Mbps:8(8/11),36Mbps:8(8/11),
                         48Mbps:8(8/11),54Mbps:8(8/11),HT20-0:8(8/11),
                 status: running-ap
                         HT20-1:8(8/11),HT20-2:8(8/11),HT20-3:8(8/11),
                         HT20-4:8(8/11),HT20-5:8(8/11),HT20-6:8(8/11),
                         HT20-7:8(8/11),HT40-0:8(8/11),HT40-1:8(8/11),
                         HT40-2:8(8/11),HT40-3:8(8/11),HT40-4:8(8/11),
                         HT40-5:8(8/11),HT40-6:8(8/11),HT40-7:8(8/11)
    notify-external-fdb: no
Device SW16 (neighbour)
# apr/11/2021 21:18:10 by RouterOS 6.48.1
# name=CR-SW16-SXT-Dach
/interface wireless
    country=austria disabled=no distance=1 mode=station-bridge \
    nv2-preshared-key="*****" nv2-security=enabled ssid=\
    __SPW15/16-WAN-Conn__ station-roaming=enabled wireless-protocol=\
    nv2-nstreme-802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk eap-methods="" \
    group-ciphers=tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
    unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key="********" \
    wpa2-pre-shared-key="********"
[admin@CR-SW16-SXT-Dach] > /interface wireless monitor wlan1
                  status: connected-to-ess
                 tx-rate: 300Mbps-40MHz/2S/SGI
                 rx-rate: 300Mbps-40MHz/2S/SGI
                    ssid: __SPW15/16-WAN-Conn__
                   bssid: 64:D1:54:1B:5E:EF
              radio-name: 64D1541B5EEF
         signal-strength: -35dBm
     signal-strength-ch0: -38dBm
     signal-strength-ch1: -39dBm
      tx-signal-strength: -33dBm
  tx-signal-strength-ch0: -38dBm
  tx-signal-strength-ch1: -35dBm
             noise-floor: -113dBm
         signal-to-noise: 78dB
                  tx-ccq: 100%
                  rx-ccq: 100%
        current-distance: 1
                wds-link: no
                  bridge: yes
        routeros-version: 6.48.1
                 last-ip: 109.70.96.178
              encryption: aes-ccm
        group-encryption: aes-ccm
       current-tx-powers: 6Mbps:8(8/11),9Mbps:8(8/11),12Mbps:8(8/11),18Mbps:8(8/11),24Mbps:8(8/11),36Mbps:8(8/11),48Mbps:8(8/11),54Mbps:8(8/11),HT20-0:8(8/11),HT20-1:8(8/11),
                          HT20-2:8(8/11),HT20-3:8(8/11),HT20-4:8(8/11),HT20-5:8(8/11),HT20-6:8(8/11),HT20-7:8(8/11),HT40-0:8(8/11),HT40-1:8(8/11),HT40-2:8(8/11),HT40-3:8(8/11),
                          HT40-4:8(8/11),HT40-5:8(8/11),HT40-6:8(8/11),HT40-7:8(8/11)
Hope you have an idea how to troubleshoot. Thank you!
As I found in another post, I added logging for “wireless,debug”
I configured this logger on one side to memory instead of disk, but on SW16 it worked:
~Connection broke at around 20:16 (i think);
I immediately checked SW15:
 22:16:14 wireless,info wlan2: radar detected on 5500000
22:16:17 wireless,debug wlan2: must select channel
22:16:17 wireless,debug wlan2: radar reported on 5500000
22:16:17 wireless,debug wlan2: selected channel 5580000
22:16:17 wireless,debug wlan2: search for radars on 5580000
22:16:44 wireless,info wlan2: radar detected on 5580000
22:16:47 wireless,debug wlan2: must select channel
22:16:47 wireless,debug wlan2: radar reported on 5500000
22:16:47 wireless,debug wlan2: selected channel 5620000
22:16:47 wireless,debug wlan2: search for radars on 5620000
                 status: running-ap
                channel: 5620/20-Ce/an/DP(11dBm)
                         HT20-1:8(8/11),HT20-2:8(8/11),HT20-3:8(8/11),HT20-4:8(8/11),HT20-5:8(8/11),HT20-6:8(8/11),HT20-7:8(8/11),HT40-0:8(8/11),HT40-1:8(8/11),
                         HT40-2:8(8/11),HT40-3:8(8/11),HT40-4:8(8/11),HT40-5:8(8/11),HT40-6:8(8/11),HT40-7:8(8/11)
Last log on SW16 shows:
Apr/11/2021 22:20:59 wireless,debug 80:2A:A8:A4:63:CA: on 5500 AP: yes SSID  caps 0x511 rates 0xOFDM:6-54 BW:1x SGI:1x,4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
Apr/11/2021 22:20:59 wireless,debug 02:5B:A8:D4:D3:A4: on 5500 AP: yes SSID 3HuiTube_5Ghz_D3A4 caps 0x511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
Apr/11/2021 22:20:59 wireless,debug DC:9F:DB:98:9B:1B: on 5540 AP: yes SSID sek-feuerkogl2 caps 0x511 rates 0xOFDM:6-54 BW:1x SGI:2x HT:0-15 basic 0xOFDM:6,12,24 MT: yes
Apr/11/2021 22:20:59 wireless,debug 10:0C:6B:55:71:9D: on 5540 AP: yes SSID  caps 0x1511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-31 VHTMCS:SS1=0-9,SS2=0-9,SS3=0-9,SS4=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
Apr/11/2021 22:20:59 wireless,debug 92:14:66:A4:F4:D8: on 5500 AP: yes SSID 3Tube_5Ghz_F4D8 caps 0x511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
Apr/11/2021 22:20:59 wireless,debug wlan1: no network that satisfies connect-list,  by default choose with strongest signal
Apr/11/2021 22:20:59 wireless,debug wlan1: failed to select network
as nothing happened and I had no connection to SW16, I rebooted SW15 at around 22:27:
22:28:09 wireless,debug 02:5B:A8:D4:D3:A4: on 5500 AP: yes SSID 3HuiTube_5Ghz_D3A4 caps 0x511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
22:28:09 wireless,debug 80:2A:A8:A4:63:CA: on 5500 AP: yes SSID  caps 0x511 rates 0xOFDM:6-54 BW:1x SGI:1x,4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
22:28:09 wireless,debug 10:0C:6B:55:71:9D: on 5540 AP: yes SSID  caps 0x1511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-31 VHTMCS:SS1=0-9,SS2=0-9,SS3=0-9,SS4=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
22:28:09 wireless,debug DC:9F:DB:98:9B:1B: on 5540 AP: yes SSID sek-feuerkogl2 caps 0x511 rates 0xOFDM:6-54 BW:1x SGI:2x HT:0-15 basic 0xOFDM:6,12,24 MT: yes
22:28:09 wireless,debug 92:14:66:A4:F4:D8: on 5500 AP: yes SSID 3Tube_5Ghz_F4D8 caps 0x511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
22:28:09 wireless,debug 64:D1:54:1B:5E:EF: on 5500 AP: no SSID __SPW15/16-WAN-Conn__ caps 0x0 rates 0xOFDM:6-54 BW:1x-2x SGI:1x-2x HT:0-15 basic 0x MT: no
22:28:09 wireless,debug wlan1: no network that satisfies connect-list,  by default choose with strongest signal
22:28:33 system,error,critical System rebooted because of ping watchdog timeout
22:28:33 system,info router rebooted
22:28:34 bridge,info "bridge1" mac address changed to 64:D1:54:BA:AC:4A
22:28:34 bridge,info hardware offloading activated on bridge "bridge1" ports: ether1
22:28:35 interface,info ether1 link up (speed 100M, full duplex)
22:28:37 wireless,debug wlan1: must select network
22:28:37 wireless,debug 64:D1:54:1B:5E:EF: on 5500 AP: no SSID __SPW15/16-WAN-Conn__ caps 0x0 rates 0xOFDM:6-54 BW:1x-2x SGI:1x-2x HT:0-15 basic 0x MT: no
22:28:37 wireless,debug 02:5B:A8:D4:D3:A4: on 5500 AP: yes SSID 3HuiTube_5Ghz_D3A4 caps 0x511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
22:28:37 wireless,debug 10:0C:6B:55:71:9D: on 5540 AP: yes SSID  caps 0x1511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-31 VHTMCS:SS1=0-9,SS2=0-9,SS3=0-9,SS4=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
22:28:37 wireless,debug DC:9F:DB:98:9B:1B: on 5540 AP: yes SSID sek-feuerkogl2 caps 0x511 rates 0xOFDM:6-54 BW:1x SGI:2x HT:0-15 basic 0xOFDM:6,12,24 MT: yes
22:28:37 wireless,debug wlan1: no network that satisfies connect-list,  by default choose with strongest signal
22:28:37 wireless,info 64:D1:54:1B:5E:EF@wlan1 established connection on 5500000, SSID __SPW15/16-WAN-Conn__
Shouldn’t the watchdog timer trigger earlyer?? “/system watchdog set auto-send-supout=yes watch-address=192.168.99.1”
While you might get upset about watchdog not triggering you really should adjust list of allowed frequencies so that “master device” (sw15) doesn’t select a DFS frequency by setting skip-dfs-channels=all … even if reboot occurred earlier it could still happen that sw15 selects a DFS frequency and later detect radar. It would again re-select frequency and whenever AP selects DFS frequency, it has to wait and scan for radars for certain amount of time (1 to 10 minutes).
You should also set master (sw15) wireless interface to installation=outdoor because that’s what it is.
Done - but shouldn’t DFS=ALL be set by my regulatory domain? Why is this important? Should it be enabled on both - master and slave?
wow - but this didn’t work as planned.
As soon as I activated it:
08:55:57 wireless,debug wlan2: must select channel
08:55:57 wireless,debug wlan2: radar reported on 5500000
08:55:57 wireless,debug wlan2: failed to select channel
You should also set master (sw15) wireless interface to > installation=outdoor > because that’s what it is.
Both SXT are set to outdoor - I changed to indoor and back, but it is still not visible in the export file. I think, because it’s default.
Default is to use all channels feasible. The lsit depends on a) regulatory domain, b) selection of indoor vs. outdoor vs. any . The problem with DFS channels is (as I already hinted at) is that when AP chooses to use DFS channel, it needs to scan for radars (it has to be silent during that) and that can take 1 minute or 10 minutes (depending on particular channel). After AP chooses such channel, it needs to monitor it for any sign of a radar and if it detects a radar, it has to stop transmitting at once and select another (radar-free) channel. If you are affected by radar detection frequently and you’re annoyed about it, then you better configure AP not to use DFS channels.
The important setting is on AP (master of bridge). It’s AP which does channel selection, it’s AP which does monitoring for radars. Slave (client) only follows master. Hence it’s best to leave client to as wide configuration as possible and make master as specific as desired.
Hmmm … looking at wireless info for austria it seems that there isn’t any non-DFS outdoor channels in austria?
[u@r] /interface wireless info> country-info austria
ranges: 2402-2482/b,g,gn20,gn40(20dBm)
2417-2457/g-turbo(20dBm)
5170-5250> /a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(23dBm)/passive,> indoor
5170-5330> /a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(20dBm)/> dfs> ,passive,> indoor
5250-5330> /a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(20dBm)/> dfs> ,passive,> indoor
5490-5710> /a,an20,an40,ac20,ac40,ac80,ac160,ac80+80(27dBm)/> dfs> ,passive
5190-5310/a-turbo(20dBm)/dfs
5180-5300/a-turbo(20dBm)/dfs
5520-5680/a-turbo(27dBm)/dfs,passive
5510-5670/a-turbo(27dBm)/dfs,passive
902-927/b,g,g-turbo,gn20,gn40(30dBm)
Which means automatics won’t work nicely, you’ll have to construct channel list manually (use scan-list=… property of wireless interface). You could start off with full list and then remove channels which your AP detects to be affected by radar. Note that when AP detects a radar, it’s not always a real radar, quite often there are false positives. Which affect the channel selection nevertheless.
Could be it’s default for SXT indeed.
Thank you for your explanation - I will try this in the evening when the kid’s don’t need the internet for home schooling.
And now the watchdog seems to work (i didn’t change anything) and thanks to debug,wireless logging to file I get a complete picture:
MASTER SW15
09:58:02 wireless,info wlan2: radar detected on 5500000
09:58:05 wireless,debug wlan2: must select channel
09:58:05 wireless,debug wlan2: radar reported on 5500000
09:58:05 wireless,debug wlan2: selected channel 5660000
09:58:05 wireless,debug wlan2: search for radars on 5660000
09:59:05 wireless,debug wlan2: no radar detetected, start network
09:59:20 wireless,debug wlan2: 64:D1:54:BA:AC:4B not in local ACL, by default accept
09:59:20 wireless,info 64:D1:54:BA:AC:4B@wlan2: connected
SLAVE SW16
09:58:10 wireless,debug wlan1: must select network
09:58:10 wireless,debug E2:C1:9E:62:2E:D2: on 5500 AP: yes SSID 3Tube_5Ghz_2ED2 caps 0x511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
09:58:10 wireless,debug 80:2A:A8:A4:63:CA: on 5500 AP: yes SSID  caps 0x511 rates 0xOFDM:6-54 BW:1x SGI:1x,4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
09:58:10 wireless,debug DC:9F:DB:98:9B:1B: on 5540 AP: yes SSID sek-feuerkogl2 caps 0x511 rates 0xOFDM:6-54 BW:1x SGI:2x HT:0-15 basic 0xOFDM:6,12,24 MT: yes
09:58:10 wireless,debug 10:0C:6B:55:71:9D: on 5540 AP: yes SSID  caps 0x1511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-31 VHTMCS:SS1=0-9,SS2=0-9,SS3=0-9,SS4=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
09:58:10 wireless,debug 02:5B:A8:D4:D3:A4: on 5500 AP: yes SSID 3HuiTube_5Ghz_D3A4 caps 0x511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
09:58:10 wireless,debug E2:C1:9E:BA:9D:7B: on 5640 AP: yes SSID 3neo_5Ghz_9D7B caps 0x511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
09:58:10 wireless,debug wlan1: no network that satisfies connect-list,  by default choose with strongest signal
09:58:10 wireless,debug wlan1: failed to select network
<lot of the same>
09:59:01 system,error,critical System rebooted because of ping watchdog timeout
09:59:01 system,info router rebooted
09:59:01 bridge,info "bridge1" mac address changed to 64:D1:54:BA:AC:4A
09:59:01 bridge,info hardware offloading activated on bridge "bridge1" ports: ether1
09:59:03 interface,info ether1 link up (speed 100M, full duplex)
09:59:04 wireless,debug wlan1: must select network
09:59:04 wireless,debug 80:2A:A8:A4:63:CA: on 5500 AP: yes SSID  caps 0x511 rates 0xOFDM:6-54 BW:1x SGI:1x,4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
09:59:04 wireless,debug DC:9F:DB:98:9B:1B: on 5540 AP: yes SSID sek-feuerkogl2 caps 0x511 rates 0xOFDM:6-54 BW:1x SGI:2x HT:0-15 basic 0xOFDM:6,12,24 MT: yes
09:59:04 wireless,debug 10:0C:6B:55:71:9D: on 5540 AP: yes SSID  caps 0x1511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-31 VHTMCS:SS1=0-9,SS2=0-9,SS3=0-9,SS4=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
09:59:04 wireless,debug E2:C1:9E:BA:9D:7B: on 5640 AP: yes SSID 3neo_5Ghz_9D7B caps 0x511 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-15 VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6,12,24 BW:1x VHTMCS:SS1=0-7 MT: no
09:59:04 wireless,debug 64:D1:54:1B:5E:EF: on 5660 AP: no SSID __SPW15/16-WAN-Conn__ caps 0x0 rates 0xOFDM:6-54 BW:1x-2x SGI:1x-2x HT:0-15 basic 0x MT: no
09:59:04 wireless,debug wlan1: no network that satisfies connect-list,  by default choose with strongest signal
09:59:05 wireless,info 64:D1:54:1B:5E:EF@wlan1 established connection on 5660000, SSID __SPW15/16-WAN-Conn__
So the master detects a conflicting RADAR as you already said and chooses a new channel. Without the watchdog, the slaves stays on the wrong channel until he gets a timeout. Then rescans and connects properly.
With the configuration “DFS=all” it detects radar on 5500, but tries to stay on it, so there could be a problem with my frequency list.
Update: Country=Austria + FrequencyMode=regulatory-domain + SKIP DFS Channels=all → not possible, because then no frequency is left!
My ScanList is “default”
According to the Austrian regulations the frequency “5150 – 5350” is allowed for indoor and “5470 – 5725” up to 1W with DFS+TPC.
Today I had the problem, that the master didn’t find any free frequency for nearly an hour?
As the two APs are directly looking to each other - why not change to indoor and lower power? This would disable DFS if I understand correctly?
Or: change to a custom scanlist - but how could i determine the right one? There seems to be a device with inproper configuration interfering with my ptp connection.
or: change from austria to no-country and setting a correct scanlist. Frequency Mode superchannel is not allowed with country=Austria.
