why did you stop supplying SXTG ac with L4 license? It was a good device for a 25° sector?
THX
THX
Here is the sector model: https://mikrotik.com/product/RBSXTG-5HPnD-SAr2
The device you refer to, is no longer in production, so we didn’t stop supplying L4 license … we stopped making it. The new device is https://mikrotik.com/product/sxtsq_5_ac
The SA has a 90 ° angle and a lot of noise in the city.
pity ![]()
If you want HQ by RF Elements 30° Horn and Use M11g with AC Module in TPA-RBC
Don’t buy ARM Hardware it is BETA Stadium, don’t work as aspected!
Horn is not economically profitable for some locations.
Interesting, it seems to me that after the latest updates the army works well.
No it doesn’t…
@mistry7 Hi, can you tell me what is better combination for HORN antena:
RouterBOARD 922UAGS-5HPacD
or
RouterBOARD RBM11G with R11e-5HacD
I see that on a 2nd combination the CPU and RAM is much better but the output power in MW are only 500.
Do you have some suggestion for the mini PCI card?
How much dBm are allowed to you?
WE use M11g and hopefully we are able to upgrade to 802.11ax with upgrading PCIE Module only…
or
Do you have some suggestion for the mini PCI card?How much dBm are allowed to you?
The max is 1w or 30 dBm
I wona use it as a ptm
or
WE use M11g and hopefully we are able to upgrade to 802.11ax with upgrading PCIE Module only…The max is 1w or 30 dBm
So with a sector antenna (Gain between 15 and 20dBi) it is allowed to you to do
10-15dBm out of your wireless Module. 15dBm are 32mW, so why you need more then 500mW Module Power?
or
I wona use it as a ptmSo with a sector antenna (Gain between 15 and 20dBi) it is allowed to you to do
And what you sugest its bether to go with rmb11g.
Yes
or
10-15dBm out of your wireless Module. 15dBm are 32mW, so why you need more then 500mW Module Power?And what you sugest its bether to go with rmb11g.
When u switch to Ax standard, do i need to change also a hardware at my clients or it will remain same and only the software will be upgraded?
You will need all new wireless interfaces for full 802.11ax support.
