SXTsq 5 ac - deleting configuration before selling
I plan to sell my SXTsq 5 ac so I want to delete my old configuration with passwords etc.
I reset the device and the configuration is gone.
Are there any automatic configuration backups I must delete manually?
Thank you for your answers :slight_smile:
Simply reset configurations and make sure that file list is empty.
Regards.
Setting it to default config would be ok. Don’t just set it to clean config.
Empty config can be a PITA for the next user.
Thank you for your answer.
I deleted the files except for the the “Flash” folder - the type column says it’s a disk.
The memory still seems to be used by something: 12.6 MiB of 15.2 MiB used.
Hi, it seems that the reset set it back to the factory settings - admin without password, LAN ip 192.168.88.1, etc.
It’s normal that a lot space is used because it’s RouterOS installed on your device. So you can’t see these files for security reasons.
Regards.
Ok, thank you!
