SXTsq 5 ac question
Has anyone connected 2 x SXTsq 5 ac in bridge mode and what was the maximum distance obtained?
Richard
33Km, but is just for control one pump (on/off, water level, diesel level) [now replaced wit wAP LTE]
More is the distance, less is the bandwidth…
Thanks rextended I am only going 1.25 Km had thought of using Cube 60Pro ac but that gives 1 Km then up to 2.4 Km so guessing 60 Ghz fails at 1 km and switches to 5 Ghz for greater range. I have no knowledge on the 60 Ghz ranges. So blind there.
For 1,25 Km? Or you have everytime perfect weather, or is better two DISC 5 ac
Very rainy rural north Wales.
NOT use 60GHz!!!
Thanks for the info rextended I will go for 5 Ghz. I think its the safest bet.
Richard
