ptp link is like 200m. The max throughput I’m able to get is 160mb of 400mb bandwidth available. Has anyone achieved higher?
link status
Strength -53/-53 dBm
ccq 93/88 %
signal to noise 55 dB
protocol nstreme
this is my configuration
PTP BRIDGE AP
# feb/18/2018 16:33:56 by RouterOS 6.42rc28
# software id =
# model = RouterBOARD SXTsq G-5acD
# serial number =
add name=AP-bridge
set [ find default-name=ether1 ] mac-address=XX:XX:XX:XX:XX:XX
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-onlyac channel-width=20/40/80mhz-Ceee \
country=XXXX disabled=no frequency=XXXX frequency-mode==superchannel mode=\
bridge name=wlan2 ssid=XXXXXX tx-power=13 tx-power-mode=\
all-rates-fixed wds-default-bridge=AP-bridge wds-mode=dynamic \
wireless-protocol=nstreme
/interface wireless nstreme
set wlan2 enable-nstreme=yes framer-policy=best-fit
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik wpa-pre-shared-key=XXXXXX \
wpa2-pre-shared-key=XXXXX
/ip hotspot profile
/port
set 0 name=serial0
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
add bridge=AP-bridge hw=no interface=ether1
add bridge=AP-bridge interface=*1
add bridge=AP-bridge interface=wlan2
add interface=ether1 list=WAN
add interface=wlan2 list=LAN
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=AP-bridge
/ip dns static
add address=192.168.88.1 name=router.lan
/system clock
set time-zone-name=America/XXXXX
/system identity
set name=Mikrotik-AP
/system package update
set channel=release-candidate
/system routerboard settings
set silent-boot=no
PTP-CPE-BRIDGE
# feb/18/2018 16:48:50 by RouterOS 6.42rc28
# software id =
# serial number =
add name=cpe-bridge
/interface wireless
set [ find default-name=wlan1 ] band=5ghz-a/n/ac channel-width=20/40/80mhz-Ceee \
country=XXXX disabled=no frequency-mode=superchannel mode=station-bridge \
ssid=ptp-wifast-jowy tx-power=13 tx-power-mode=all-rates-fixed \
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk group-ciphers=\
tkip,aes-ccm mode=dynamic-keys supplicant-identity=MikroTik \
unicast-ciphers=tkip,aes-ccm wpa-pre-shared-key=XXXX \
wpa2-pre-shared-key=XXXXxxx
/ip hotspot profile
/port
set 0 name=serial0
add bridge=cpe-bridge interface=wlan1
add bridge=cpe-bridge hw=no interface=ether1
set discover-interface-list=all
add interface=wlan1 list=WAN
add interface=ether1 list=LAN
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=cpe-bridge
/ip dns static
/system clock
/system identity
set name=MikroTik-CPE
set silent-boot=no
