SXTsq lite5
Hello friends, someone has a total configuration of a SXTsq lite5 client mode. Thank you for your help.
Can you clarify, what kind of setup are you planning?
Where will it be connected? Is the other device also controlled by you?
A wifi configuration from a client, it will be connected at a friend’s house, if the other device is also controlled by me
