SXTsq Lite60
Saw this announcement and got excited: A (cheaper) radio that fills the awkward gap between 100m and 200m on a multipoint Wirless Wire AP where a dish feels like overkill.
But… it only has a 100 Mbps port. :open_mouth:
I know it’s cheaper, but not having a gig port is a major bummer :frowning:
it is a client device for multipoint setups, so if your wAP60G has Gigabit port and capabilities, you will split it into 8 clients. Then each client doesn’t need 1Gbit port.
At 100% utilization, sure, but that’s usually not the case. Even with overhead, a single station on a quiet 8-station wAP 60G should (hopefully?) see 1 Gbps half duplex.
Still, with the latest firmware, the original Wireless Wire goes pretty far. Anything further than 150m we’ll keep using the dish.
I suggest looking at this product from the mentioned point of view. For higher requirements, we still have the other models.
how about ptp scenario with SXTsq lite 60 ? is fast ethernet sufficient?
how about less than 8 CPE , for example 3-4 cpe is FE solution to waste capacity of 2ghz wide channel ?
another great idea from mikrotik, no doubt.
RB711G/911G with GE that is merely capable to transfer over 100mbps, but SXTsq that should link 2160mbps and transfer over 1gbps receive Fast Ethernet, brilliant!
@Normis the limit of 8 clients per AP 'll updated to 16 ore more clients in next future?
Can I make point to point link with 2pcs sxtsq lite60? I need it for 300 meters distance
Possible but I will drop on every rain
if I have under 200m distance
can I make a bridge between these SXTsq-60ad’s?
if the 5GHz is full, it can be safe and stabile?
200m is the limit but it 'd work
