binary
April 11, 2006, 9:37pm
1
We are having huge syn packets to our Debian Sarge server.
We have Mikrotik 2.9. I had tried lots of things but non resolve.
I set two rules to block them but not working well.
chain=forward in-interface=eth2-Telekom dst-address=212.175.229.170 protocol=tcp tcp-flags=syn
dst-limit=1,0,src-and-dst-addresses/10m action=accept
chain=forward in-interface=eth2-Telekom dst-address=212.175.229.170 protocol=tcp tcp-flags=syn action=drop
Rule1 says 10K packets passed, rule2 says 15K packets dropped.
After these rules, there are still syn packets on server, where you can find output @ http://www.yuhhu.com/syn.txt (Hope url working
I will be glad if you can help.
add chain=synflood protocol=tcp limit=400,5
connection-state=new action=return comment=“”
disabled=no
add chain=synflood protocol=tcp connection-state=new
action=drop comment=“” disabled=no
Jump to this chain from your input and forward chains. The first rule allows syn packets, the second rule only activates if the first rule is ‘full’.
Sam
jp1
April 12, 2006, 1:11am
3
On your linux server, be sure to enable syn cookies. If it’s compiled into the kernel, /proc/sys/net/ipv4/tcp_syncookies set to 1 enables the feature for combating syn attacks in linux.
binary
April 12, 2006, 7:32am
4
Thanks for help, I ll try the jump rule.
But isn’t 400 too large? And also restricting access by source and dest. ip via Dst. Limit won’t work?
On linux box, I ve iptables rules;
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ACCEPT tcp -- anywhere anywhere tcp dpts:ftp-data:ftp
ACCEPT tcp -- anywhere anywhere tcp dpts:50000:50050
ACCEPT tcp -- anywhere anywhere tcp dpt:ssh
ACCEPT tcp -- anywhere anywhere tcp dpt:www
ACCEPT tcp -- anywhere anywhere tcp dpt:https
ACCEPT all -- laptop.radore.net anywhere
REJECT tcp -- anywhere anywhere reject-with icmp-port-unreachable
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
ACCEPT all -- anywhere anywhere state NEW,RELATED,ESTABLISHED
And file /etc/network/options;
ip_forward=no
spoofprotect=yes
syncookies=yes
And Already set 1 in to file /proc/sys/net/ipv4/tcp_syncookies
But linux still gets down on syn attacks.
400 is an arbitrary number that I chose for the example. Actually ours is slightly higher because we see tons of traffic. Remember how a SYN packet works, you can spoof it, so limiting it by source does no good. Most synfloods will use forged IP addresses. A dst limit should be okay I would assume.
binary
April 12, 2006, 10:05am
6
I am not getting any packets when i set rule connection-state=new
Are you using connection-tracking ? If so, then maybe the jump rule isn’t passing them to this chain?
Sam
binary
April 12, 2006, 6:13pm
8
Conn Tracking is not enabled. It consumes too much cpu.
Yes, to use Connection-State=New its using the connections table. . . you should be able to replace that with the tcp flags of syn.
Sam
Even if you block the SYN flood attack , it can eat all your bandwidth and cost you downtime or money. Nasty, nasty stuff..
Yes, tell me about it : ) We saw 180mbps of spoofed synflood last week. Not fun.
Sam
