Hi, I have a hEX rb750gr3 as my main router at home, along with two APs (CAP AX and AX2). Everything generally works fine, but I can’t seem to sync devices like an irrigation system or an LG air conditioner. I’m not very knowledgeable; I’ve tried a few things, but I don’t know what else to look for. I welcome any suggestions for improving the configuration.
The hEX configuration is as follows:
# 2025-06-17 10:34:03 by RouterOS 7.19.1
# software id = 6B5U-98RN
# model = RB750Gr3
# serial number = <removed>
add admin-mac=48:A9:8A:40:36:93 auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=ether1 name=vlan20 vlan-id=20
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan20 name=pppoe-out1 user=286301565@digi
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi security
add authentication-types=wpa2-psk disabled=no name=sec1
/interface wifi configuration
add channel.band=2ghz-ax .frequency=2412,2437,2462 country=Spain datapath.bridge=bridge disabled=no name=cfg2.4G security=sec1 ssid=myrouter
add channel.band=5ghz-ax .frequency=5180-5320,5500-5700 .skip-dfs-channels=disabled comment=cfg5g country=Spain disabled=no name=cfg5g security=sec1 ssid=myrouter-5G
add name=default-dhcp ranges=192.168.0.128-192.168.0.254
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
/interface wifi capsman
set enabled=yes package-path="" require-peer-certificate=no upgrade-policy=none
/interface wifi provisioning
add action=create-dynamic-enabled comment=2.4G disabled=no master-configuration=cfg2.4G supported-bands=2ghz-ax
add action=create-dynamic-enabled comment=5G disabled=no master-configuration=cfg5g supported-bands=5ghz-ax
add address=192.168.0.1/24 comment=defconf interface=bridge network=192.168.0.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.0.253 client-id=1:d4:1:c3:f0:18:25 mac-address=D4:01:C3:F0:18:25 server=defconf
add address=192.168.0.252 client-id=1:d4:1:c3:de:81:cc mac-address=D4:01:C3:DE:81:CC server=defconf
add address=192.168.0.236 mac-address=D4:F5:47:93:EE:D0 server=defconf
add address=192.168.0.0/24 comment=defconf dns-server=192.168.0.150 gateway=192.168.0.1
set allow-remote-requests=yes servers=192.168.0.150
/ip dns static
add address=192.168.0.150 comment=defconf name=router.lan type=A
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=pppoe-out1
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" dst-port=33434-33534 protocol=udp
add action=accept chain=input comment="defconf: accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/10
add action=accept chain=input comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=input comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=input comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=input comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=input comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack6" connection-state=established,related
add action=accept chain=forward comment="defconf: accept established,related,untracked" connection-state=established,related,untracked
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" dst-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: rfc4890 drop hop-limit=1" hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 protocol=udp
add action=accept chain=forward comment="defconf: accept ipsec AH" protocol=ipsec-ah
add action=accept chain=forward comment="defconf: accept ipsec ESP" protocol=ipsec-esp
add action=accept chain=forward comment="defconf: accept all that matches ipsec policy" ipsec-policy=in,ipsec
add action=drop chain=forward comment="defconf: drop everything else not coming from LAN" in-interface-list=!LAN
/system clock
set time-zone-name=Europe/Madrid
/tool mac-server
/tool mac-server mac-winbox
