Synchronising security settings between 2 ROS 4.11
Hi!
I need sinchronising security settings between 2 router (routerboard 411ah RouterOS 4.11)
The 2 router almost same settings on all, but if i change security settings on a master router (eg. mac allow list on virtual AP, hotspot user:password etc.) i need to synchronise the slave router.
This routers placed the different buildings, but serving same personals. WDS not a solution, (if i understand right, thats need to connect on wireless side. That’s not possible. Only lan side)
Have any “easy” “click’n Click” solution, or only scripting?
Thanks!
K
Use centralized RADIUS server for authentication.
Or… User Manager (a Mikrotik solution) mrz, I’m surprised you didn’t mention that.
