Is there an up-to-date list of supported hardware for synchronous serial applications such as frame relay?
I have searched the forum, the manual, and the web, but I can only find references to rare or obsolete hardware. If anyone has recent experience of a PCI or mini-PCI serial adapter I would really appreciate hearing from you.
FarSync PCI V.35/X.21 (8.448 Mbit/s)
LMC/SBEI wanPCI-1T1E1 PCI T1/E1 (also known as DS1 or LMC1200P, 1.544 Mbit/s or 2.048 Mbit/s)
LMC/SBEI wanPCI-1T3 PCI T3 (also known as DS3, 44.736Mbit/s)
You really should update your manual and your tech support people if the wanPMC products are supported. I e-mailed about this only last month and was told support for wanPMC products would not be added until 2.10. While it’s great to find out that wanPMC support is in there now, the confusion is quiet frustrating!
I just bought a WanPMC w/ the PCI adapter. It has been working fine for almost a week now. The only comment I would like to make is that there is no facility for troubleshooting/testing circuit state. Better status reporting and testing would defiantly be on my wish list. MikroTik does not report throughput stats or anything other then up/down for this card.
My understanding is that SBE discontinued the PCI cards and now, only makes the PMC version. However this is the same card just a different form factor.
