Syncro AP using GPS
Hello Forum, I would like to know if there is any way to syncronize some APs like they were on Canopy Cluster Manager. Anybody knows Interference is critical among many APs in the same tower in the same channel, even on the same AP using more than one wireless card. May be GPS syncronization could be a solution, may be there is another way to do it.
I will appreciate you aim me to the correct point.
Thanks a lot
Ivan Perino
Feature has been asked for, not yet implemented.
