Syntax change from /cmd subcmd to /cmd/subcmd
Am I correct in assuming that the /cmd subcmd1 subcmd2 syntax is ROS 6 and /cmd/subcmd1/subcmd2 is ROS 7? /export appears to still output in the old format - I assume this is by design at the moment to maintain backwards compatibility as ROS 7 seems to be able to handle old and new syntax.
