Can someone provide me the proper syntax to establish multiple OSPF instances (one per VRF)? I can set up the instances, but don’t see any way to identify NETWORK entries as belonging to specific instances… I’m probably too Cisco indoctrinated.
I am running a backone OSPF instance tying my core MT routers together along with BGP and LDP as a mesh of PE nodes.
Assuming I want to link with my CE routers using OSPF over VLANs, how do I set up the separate OSPF instances to handle this? All of the examples assume static routing for the MPLS/BGP/LDP network and just use the single backbone OSPF instance for a single VRF… No examples show multiple VRFs.
For example network 1.1.1.0/24 is in VRF table
Configuration below will make new ospf instance, new backbone area for that instance and add network to area
It actually works much better when you force a Cisco switch port into trunking mode if the link is on a Vlan… It’s no wonder the OSPF neighbors wouldn’t set up…
If you consider using MPLS in production, I’d like to share with you two handy macros that will help you in your provisioning:
First is to add an interface to an existing vrf:
