sys logging to different log files
dude 4.0beta3 → click logs on tree (left side) → plus/add button → make new log for a router
dude 4.0beta3 → settings button at the top → Syslog tab → plus/add button → … "
add src address
action = accept
notification = log to syslog
click the little single dot button and set the target log to the log you just made for rb1
winbox to router and set up remote sys log
OK this works great but now lets repeat the steps for our next router…
result → when you go add your second router in the settings → syslog and change the target log all the sudden all the rules send all logs to the one you just added.
Am i doing this wrong or is it broken?
The wiki on syslog has you point everything at the syslog that is already in place. I did find how to customize this functionality.
You can set up different log files in the log area.
dude → logs(left tree) → plus/add button → name it appropriately.
Now create your custom notification.
dude → notifications(left tree) → plus/add button → type=log, Target Log=
Now have The Dude send the appropriate incoming syslog data to the correct log file.
dude → settings (button top left) → syslog(tab at top) → plus/add button → src address=<server’s-IP-to-collect-sysData’s-from>, action=accept, notification=
OK their we go now all Sys Log data coming from that server/routers ip is now going to our own custom log file.
Repeat the three steps for your next server/router and now all your logging Dada will be organized.
You can also set up the “Start New File” attribute when making each log. This will create a new file how ever often you like. I set it to one day then set up a cron to archive :slight_smile:.
