Syslog by Mikrotik !!!
Dear MT users,
anyone knows a syslog software to log all the activities on my MT BOX?
since the defualt syslog by mikrotik is not fully featured, and seems there
are some bugs on it.
thks in advance
Regards,
I have used SysLog2ODBC.
IT takes SysLog data and dropes it to a SQL server.
You can Slice and Dice it from there as you see fit.
Craig
You can try linux syslog or syslog-ng its free and it has a lot of features. Or you can try Kiwi Ive seen people use it in Windows.
Kiwi works great on Windows. Free version have many restrictions so you might want to buy it.
OK thanks guys,
but i’m asking why doesn’t mikrotik team update the syslog mikrotik?
I like it, because it’s really simple
take care all
development of that program stopped many years ago as they are a ton of similar programs that do the same job
