Hi there!
For unknown reasons there is no data in the Syslog file. The file is created but it’s empty.
Could you tell me what’s the problem?
Thank you!
P.S. Previously I used 3.6 version - Syslog works fine. I used The Dude under Windows 8.1 x64.
Hi there!
Thank you!
Hard to say. It works for me.
Are you sure the syslog packets are arriving to the dude and they are not dropped by hosting system firewall?
check syslog is enabled on dude and verify the port
check log generating devices configuration to asure have the correct ip of dude server
check connectivity between devices and dude server
as jarda says check syslog packets are arriving to dude server
Hi all,
i was move my Dude from windows server to MikroTik CCR1016-12G, Dude version 6.34.3.
All is fine, but syslog is not acceptable from devices, look like is not working
Syslog file is created but it’s empty.
and after reboot i every time lost the Notification “Syslog”, i recreat it and check the message by button “Test” it working.
and MikroTik CCR1016-12G not respond on 514 port. while syslog enable in menu.
in torch i see packets on 514 port
NAT and Firewall filter not block the 514 port
model CCR1016-12G
version ROS 6.34.3
firmware 3.27
serial 468702110059
