Server error: All slots used. Delete file to free up space.
I don’t know why and I can’t backup on the cloud now, where I have just one backup from the beginning of the month. Maybe you must try to delete the cloud backup and create again.
I do not care if it is one command or more. IMHO the problem is that you have to delete a valid backup. And you do not have a cloud backup until you successfully upload a new one.
There should be a replace option, that uploads a new backup, then replaces the old one only if upload was successful. If anything goes wrong existing backup must be untouched.
Yeah that’s what I’m talking about. You’ll need to remove the existing file first because… there appears to be just one slot available - which is OK I guess since it’s a free service and it costs Mikrotik money, ongoing.
You can do
/system backup cloud print
to verify that there is indeed an existing file and then
/system backup cloud remove-file number=0
to delete it… and then you’ll be able to upload a new one.
Yeah that kind of “upload, validate, then replace” would be nice, but right now there is no “replace” of any kind at all, looks like…
