System clock ticking too fast on x86 platforms bug is present from RouterOS 3.15 till latest 4.5 version. Clock ticks too fast or too slow.
There is one workaround. You must disable NTP client and then set date and time manually and finally restart x86 platform by powering it off and on. However disabling NTP Client is bad.
Please MT fix this very very very nasty and annoying bug.
Still testing, but it looks like this solved clock issue!
I’m testing ROS v4.4 right now on Alix.2D2 platform. Normis, maybe it should be good to disable multi-cpu by default on fresh ROS installs? And maybe add info about it after first login after install in Winbox (just as default config etc.)?
