SYSTEM CRASH AT USER LOGIN
Hi everybody…
I have a problem with hotspot at user login on 3.14 and ahead, let me explain…
I use mikrotik since 2 years ago, hotspot always has been worked fine, webproxy enable. This until 3.13, because 3.14 and ahead don’t work very well.
When a user log in, all system crash and i must reboot. If i bypass that user or disable hotspot everything goes ok. I repeat, system crash at same time user log in.
I’m using the same configuration than previuos 3.13 version, wich was the last who worked fine to me. I’m been upgrading from 3.13 to newer versions and always must to go back to 3.13.
Hope you can help me… Thanks in advanced
PS: Sorry about my english, i speak spanish
