I had a x86 system with a compact flash card in an IDE adapter running fine for years. Today it croaked and would keep rebooting itself after the login screen came up. I have tried to fix it by putting the same level of OS that was on it, it formatted the drive for what seemed like forever, then said it couldn’t put the original config on it because it may be out of space. When I rebooted it, it was back exactly as before. Reboot after login screen comes up. (btw, you can’t ever get a prompt when you attempt to log in).
So, next I took out the CF and put it in a USB adapter and put on my office computer and tried to do a netinstall. It saw the disk, but says failed evertime I attempt to install it.
So, back to the original x86 computer, this time I’m trying to install a previous version (it was at 3.18 and now I"m trying 3.13). This time is says “do you want to keep the current config”, of course I say yes, it then gives me the formatting warning, I say yes, and then it says that it couldn’t keep the config, current license does not allow that, and starts to format. No choice but to lose current config.
It is still formatting, erasing my existing config as far as I know, so I thought I’d throw this up here to see if anyone had any suggestions.
I have used over 100 routerboards without issues, but sure seem to have problems with x86 versions. As far as I can tell, it is not a pc issue. I tried moving the CF to another pc and had the same exact issue.
Tom
- Update* After trying to format my CF drive, it failed with a message that there wasn’t enough disk space. This is a 4gb CF. It used to be enough, maybe not anymore. Maybe that is my trouble all along.
