My Mikrotik 2.9.11 is rebooting 3-4 times a day in log I can see only System error critical, is there some log in anader place to see what exacly is the problem
Thx
Send support.rif to support@mikrotik.com
Regards
One more maybe stupid but where I can find this support.rif file
Thx.
You have to gererate it, if you use winbox on the left menu you will see it…, and you will find the generated file under Files
Regards
you can also configure automatic support.rif in system watchdog…
very very Thx for info, it was driven me crazy.
Thx again:)
Iz Srbija sad sam zabelezio. ovaj 2.9.x je nov za mene do sad sam radio na 2.8. Hvala puno:)
Speak in english please… so we can undestand what are you saying…
Regards
/system sup-output
download from the router FTP, (ftp://router_IP_address).
