System note popup every login now?
I have updated winbox and am using the latest stable 6.45.7. Every login via winbox reveals the system not popup - not just note at top of terminal.
Is this now the expected behavior and I just missed it?
It is expected in the latest RouterOS versions. You can disable it with:
/system note set show-at-login=no
Ok - thanks
Can i disable it only in Winbox logins?
That is a good question - it used to popup every time a new terminal was opened. Now it seems to do both - winbox log in and new terminal.
I probably missed this in a release note… I am used to it now - but was weird at first.
