system profiler and "unclassified" taking all CPU
Is there a way for me, the average Joe, to find out which package/process the system profiler “unclassified” refers to? This could be helpful tracing root causes for issues when the “unclassified” keeps using almost 100% of the CPU..
Send MikroTik a supout.rif … also you may want to upgrade.
Perhaps you have the System → RouterBoard window, which shows the BIOS version, open in Winbox?
Thanks! What stuff goes into supout.rif? I might not be super happy to dump all my data to an external without knowing what exactly goes in there.
100% CPU issue in my case seems to be a result of going to the latest ROS and firmware versions.. :wink:
Most of the config and some run time stuff. You can actually view it. Just make an account on mikrotik.com and there is a viewer.
…and putting the supout.rif file to the viewer means giving the unknown data to other company… (:slight_smile:
Thanks a lot! I’ll consider this viewer.
Btw.. a new day a new thing showed up. Last night when fiddling around with my setup I ended up removing one device from the 751U, my Samsung TV. Now for ~24h no permanent 100% CPU or reboots. However, after generating some traffic I got now “flash” process shown in “/tools profile” that eats 100% CPU every few seconds and of course all the time generating more write to my flash in a high pace. This is getting interesting :sunglasses:
