System Reboot Due To Kernal Failure
Hi All,
I am new to MikroTik / RouterBoard systems and need some advice.
I have a Cisco 3725 Router that controls and binds the 4 T1 lines I have comining into my shop, I use ethernet port 1 on this router for my wireless network.
I just purchased a RB-1000u to be the core router for my wireless network and everything is setup and operates just fine with one exception, I get these errors when I plug the RB-1000 into the Cisco 3725.
system error critical - System rebooted because of kernal failure
system error critical - router was rebooted without proper shutdown
When I place a switch between the 3725 and the RB-1000 it all works great, as soon as I go direct from the 3725 to the RB-1000 I get this error.
I have tried standard Cables and Crossover cables but I get the same result.
Any ideas would be greatly appriciated,
Thanks,
Dean
Problem Solved By Support
Auto Negotiation was the problem!
