System rebooted because of kernel failure
Hello Boys
I have a problem on a station that I carry around for several months.
Initially the station had installed a radio modules with 2 RB800 Ubiquiti SR71-15 as a power system I used a switching power supply 24V 6A battery that served as UPS, which gave me the problem was that every time the card was going to block and so I was forced to physically disconnect the power connector and plug it, then everything went back to work for a certain period of time until risuccedeva the same thing.
Then, tired of making up and down the roof I have replaced the RB800 with RB433 I went over the configuration and re-assembled everything, same problem after a week, at this point I thought it was a power problem so I unplugged the switching battery system and I connected directly to a 24V PoE, now the problem is more often the only station restarts and I check out the following message:
router was rebooted without proper shutdown (cause 1)From what you can depend on?
What evidence can I do to permanently solve this problem?
