for a 3G usb modem reset, makes the entire system reboot unexpectedly with no autosupout file created for it.
currently on RoS 5.24, latest firmware too.
Any ideas? I can rerun it myself many times, and wont get the failure, but now since I’m doing doing remote logging, I can see this problem is related to the usb reset in a script of mine. If I omit the reset command it never happens. (So the bug, is either that a ppp-out for a 3g is changing to running state is causing the issue, or, the usb power-reset is causing the issue)
May I ask how you connect the 3G usb device to the rb2011? (Where did you find a cable with micro usb male in one end and regular usb female in the other?)
