"/system reset" not working?
Hi users,
we have a strange problem here. We are unable to reset the configuration
of a licensed MT on a WRAP board.
MT version was 2.9.29 installed on CF card. A "/system reset" leads to
the usual reboot. After reboot the password was changed to an unknown
one. It was not "empty" as the default login. It was not the old one.
After manualy reseting the password we got access to the system and
saw that the configuration (IP adresses, hotspot, ..) is still there.
We typed in a second "/system reset". After reboot, same situation, no
login possible due to unknown password. Reset password again, Got login.
Still the same configuration.
After that we upgraded the system to the newest version, 2.9.38.
We thought, perhaps there is a bug in the 2.9.29 reset command.
After upgrading we tried the new "/system reset-configuration". Reboot.
After reboot the password was reset to "blank", OK! .. But all config
settings are still there ...
Very strange. We have never had any problems mit the reset command.
Anyone had the same experiences?
seandsl
maybe upgrade first! you are ten versions behind
Probably, you have used Netinstall script to set basic configuration to the router.
This configuration is reverted back after the ‘system reset’.
Normis: As you see above I upgraded already, same error. No reset possible.
Sergejs: No, I haven't used netinstall. I didn't manage to PXE boot the WRAP board. We do always use the CF image.
Any help how to do a full reset ??
seandsl
Something strange here. After the first /system reset how were you able to “manualy reset” the password?
I'm sorry, but forum rules prohibit an answer to this question.
seandsl
No problem, I read quick. :slight_smile: But anyway, I just did a reset config on a wrap with 2.9.34. All wiped including password.
freebird, very strange situation. You can try to find USB-CF adapter and reinstall router without saving old configuration using Windows netinstall.
Then add basic configuration to WRAP, and perform ‘/system reset’ once more, I have only RouterBOARDs, there are not any problems with ‘/system reset’ on them.
OK, I selected all necessary packages in netinstall, choosed the USB/CF
adapter as drive and pressed install.
During first boot the MT install routine formated the drive. We had been
a little bit nervous because we thought that the license has been gone
now. But it didn't. After reboot still Level 4 licensed and clean and fresh
configuration.
Tried to change password and enabled dhcp-client, done a reset, and
everything is gone. Fine, Thanks.
The old install must have been kind of "unwanted config state" where
reset didn't worked fully. Had never had any problems with reset a
MT installed on WRAP before.
seandsl
One note to add, Netinstall and CD install will not erase the current license.
Third-partition tools can erase the current license.
