Hi there,
I have studied the wiki page for the system/scheduler which reads:
“If more than one script has to be executed simultaneously, they are executed in the order they appear in the scheduler configuration. This can be important if one scheduled script is used to disable another one. The order of scripts can be changed with the move command.”
This makes sense except that I cannot find any “move” command to reorder the scheduled tasks and Winbox does not allow you to drag the tasks around. Am I missing something here or is this a bug in the system? It is the same on 6.35.2 and 6.12 so nothing recently changed.
Comments and advice welcomed.
