I use RB 951Ui 2HnD as regular wireless router but I see that can be used for much more than that. What I would like to do is, add 2 Tagged VLAN’s to WAN port (VOIP and IPTV) and bridge them to two specific interface as Untagged. No changes with DATA on WAN interface which should stay Untagged and NAT-ed.
I believe there is somebody who already did this and can point me to the right way or show me how to do that. I know how to do that on Cisco and Extreme equipement but Mikrotik is new world for me.
Thank you in advance
For better understanding see scheme!
Create two VLAN interfaces on WAN interface with the correct tags (you didn’t specify so I’m going to use 10=voip and 20=iptv in my example)
New Interface → Name=WAN.10, VLAN ID = 10, Interface=WAN
New Interface → Name=WAN.20, VLAN ID = 20, Interface=WAN
(note that the name doesn’t matter - it just helps you identify the vlan ID in the interface list when clicking drop-downs)
On the VoIP bridge, add two interfaces: WAN.10 and Ether4 (Be sure that Ether4 is not running slave to any other ports)
On the IPTV bridge, add two interfaces: WAN.20 and Ether5 (same for ether5)
That should do it, and will leave the existing IP configuration on WAN and ether2-3 untouched.
I was in the same boat - I could do it in my sleep with Cisco, but couldn’t do the same in Mikrotik until I thought it through. After getting the right mindset for MT, it is easy too.
