Tagged VLANs
Hi!
I need to send tagged traffic via Wireless link from Omitik to two SXT’s and untag one of VLANs on SXT’s ethernet port. Second VLAN, that is send to SXT is used as management networt for device itself.
switch --VLAN 21,253 tagged—> Omnitik Eth1 (IP in VL253 for management) → Wireless → SXT (IP in VL253 for management) → VL21 untagged on Eth port → PC
Diagram in attachment
PS: can not use multiple cables for Omnitik. It seats on the top of the roof with no real access to it without crane :slight_smile:
Mikrotik Wireless.pdf (139 KB)
Put in wds mode, and “what goes in goes out”.
i need to “keep” VLAN253 traffic on device for management and untag VLAN21 traffic on SXT to connect 1 PC directly to it’s LAN port. Manageable switch is not foreseen on SXT side to untag the traffic…
Could you post the current sxt config?
Have you tried bridging vlan21 to the ether1 on the sxt? If you run torch and activate the vlan monitoring option do you see tagged traffic on the ptplink?
