Tahoe 932 v.35 interface
Any one knows is there possibility to run Tahoe 932 v.35 interface under mikrotik ???
http://www.tahoe.pl
Please HELP ME !!!
:confused: I only read English, German, Spanish and French. However, the information I could get for this board shows that it is almost the same as a MOXA-C101 board.
The MOXA-C101 is supported by Mikrotik (See User Manual)
Ok, but how can i add this interface to the list, i have in my computer 2 ethernet adapters, and mikrotik detect it fast, but dont se any other interface.
HELP !!!
Someone can help me ???
:slight_smile: Before you try to find these interfaces, you have to be running Level 5 routerOS. Level 5 enables the sync. interface section
IF you have level 5 install and it does not see the card, it will most likely not work.
actually level 4 enables Sync.
