My RouterBoard 433 will boot beep once, then later beep twice in a higher pitch, I have no ethernet access.
I used HyperTerminal and a correct Null-Modem Serial cable, I connect with 9600 bits per second; 8 data bits; no parity, 1 stop bit and hardware flow control.
My problem is, I receive nothing but random text characters when I boot up the RouterBoard.
Does the RouterBoard require a certain Emulation setting?
How would I go about fixing this problem, I need to reinstall the RouterOS but can not access the BIOS on the RouterBoard.
Many folks who are trying to connect to a serial terminal / console session may be trying to re-establish administrative control after making a mistake in their firewall rules. This happened to me a few days ago, and I struggled and struggled to get the serial cable/session going. For everyone in that boat, there is an easier answer:
Download and unzip “Neighbour viewer for Windows” free from the Mikrotik web site.
Install it on a PC local to the router (not behind another router).
Get it to ‘discover’ your router, then press the button to initiate a terminal session (using its own built-in terminal that connects by MAC address, not by IP)
Log-in to the terminal session like you would any other SSH session. Fix your firewall so that you can again connect by your method of choice.
