Hi
Anyone use tapatalk and mikrotik forum?
My say
an SQL error occurred while fetching this page.
Cant log in
admin ??
Anyone?
Admins?
Work perfectly, writing right now.
Best, Bam
i try again right now
not working
tapatalk pro on ios
anyone else ??
Even as I speak (or write), tapatalk pro on Android, no problems whatsoever…
So you perhaps have some system-wide adblocker or trace-blocker that might f*ck up things installed?
Sent from my H8266 using Tapatalk
auto login via tapatalk pro IOS
https://prnt.sc/pvavt2
manual login with username and pass
https://prnt.sc/pvaw2h
normal iphone 8
version tapatalk 8.5.3 (2403)
I try also remove, install again
I try also install free tapatalk, same problem
Testing
Sent from my Nexus 6 using Tapatalk
Same here. It doesn’t work on iPhone (since at least 2 years)
So can the trouble description be formulated more precisely as “Tapatalk (regardless whether free or pro) on iPhone does not work specifically with forum.mikrotik.com, while it does work just fine with at least one other forum”?
Precisely.
OK, so it’s finally clear that it is not a specific issue of the OP’s phone, and therefore it makes sense to send an e-mail to support@mikrotik.com with a link to this topic to let them have a look how Tapatalk connections coming from iPhones are handled.
Hi
We are aware of the issue. It’s being looked into by the Tapatalk developers.
and again waiting
admin forum how long ??? tapatalk support find solution, but admin is where ?
and again
like mikrotik OS support, nothing best with forum support
Link to support tapatalk
tapatalk say, ios have problem to log in to mikrotik tapatalk app
And admin dont have time, or dont want fix.
+1 to let a forum admin contact the tapatalk support people!!
any news for tapatalk plug in ?
New plugin will be released early next week.
It turns out that Tapatalk doesn’t support the latest PHPBB version. They are working on a new plugin now. Hopefully it will resolve all issues.
How about making the relative time in default skin either configurable per user or disabled altogether?
It’s atill ugly as a sin, uninformative as babushka’s babbling and broken on certain combination of browser and OS. Plus it’s different than it used to be, hence request to make things the same as they used to be should be taken seriously. I’ve failed to notice any plea for forum change with regard to this matter …
The forum upgrade also broke the skin and some included plugins. We plan to disable the one responsible for time conversion.
