I want to check if some port are open in my remote host.
I try :
probe->TCP->port 3389->Connect only
but status is always OK.. even if service is down and port is close. Please help
Dude v3.5
Dude v3.6
Dude v4.0beta3
PS. I also try it but not working for me:
I try witch
“1.3.6.1.2.1.2.2.1.8.3389”
“3389”
1.3.6.1.2.1.2.2.1.8.3.3.8.9
This probe is universal for any device, including switches, routers, Windows servers or workstations:
Code: Select all
<?xml version="1.0" ?> 13 20853 interfaces port status port 01 5 10001 1.3.6.1.2.1.2.2.1.8.1 integer == 1Just change SNMP OID from 1.3.6.1.2.1.2.2.1.8.1 (this one is for first port in system) to number of port you need.
On Windows Severs this number can be high (like 65530), so don’t be surprised if you see something like that in SMNP Walker. >
If port is up, then value is 1. If down, value is 2 and alarm raised.
Probe from original post is to check if some service (and 465 is Secure SMTP) running on device. This is not related to interface port on device.
